D & S Super 5000 Breaker popping
Louise
The wash starts, the carriage moves forward and suddenly the machine stops. Gantry breaker pops on outside of control cabinet. We have searched and searched for a loose connection or other wiring problem. Just cannot find anything.
Can you guys help?
Louise
Yes, we did change the breaker. Didn't fix the problem. Any other ideas?
CT.
Could be a flat spot in a motor, had this problem before on a automatic, everything would be fine then for no reason it would trip the breaker, changed breaker would work then trip, changed motor no more problems
robblackburn
Louisville, Ky.
coils on hydrolic unit
Check out the coils on the Hydrolic unit. If they are bad will cause this breaker to pop. If it is hot to the touch then probably bad.
Rob
Louise
Fixed the problem. After chasing our tails with no results, I called a control specialist. With 2 hours ($100) he had the problem fixed.
It was a stuck Dema that would not activate and tripped the breaker.
