D&S 5000 Troubles
CarWashHelp
Hello all,
Have a D&S 5000 that's about 10 years old. I can't figure out how to fix these problems that have creeped up. Not sure if they're related or what.
Presoak only activates for 5 seconds or so, and then after that only misty water for the rest of the arch passes. If I manually run the Presoak relay (#8), the presoak comes out really nice. I replaced all 3 presoak check valves today, one of which was bad.
Triple foam only works for 5 seconds or so as well. Works nice for those 5 seconds, and then it's just spitting out air.
Side nozzles work on first high pressure pass, but on second high pressure pass, they stop working.
I am stumped...anyone have any ideas? Thank you for your help.
