Having an issue with my Vendmaster. The unit will accept coins, but no motors will turn once an item is selected. Bill acceptor is flashing 2 count; indicating "disabled by machine". The 7512i cashflow display reads "check vendor, disabled by machine".
The 26 page manual does not address this issue. When I run a motor test, none of the motors turn.
I am assuming I have a control board issue, or a harness issue. I did see 2 wires a bit crimped where they got caught in the door. I cut and re-splced those. Other than that, the harnesses look good.
I just wanted to see if anyone else has had this issue before I attempt to call in to D/H. Thanks in advance for any help.
