My IBA started acting very screwy yesterday. Intermittently, the gantry would begin travelling down the rail prior to the car entering the treadle pad!
I determined it was either a) the floor switch or b) a broken, loose, or corroded wire.
It was very cold yesterday and we washed alot of cars. It only happened once, near the end of the day, then seemed fine. The problem occurred again this morning with a line 6-deep for the auto bay (of course!).
Shut the bay down. Powered down. Pulled the cover off the junction box where the treadle wires go. There was water inside and evidence of corrosion. I pulled all the wires out carefully and found 2 broken wires and 6 corroded connections under the wire nuts. I dried everything out slowly with my heat gun. Repaired the breaks, stripped back and cleaned up the corroded wires and reassembled the junction box. Put some clear silicone around the cover.
Bingo. We're back in business. But I am ordering another floor switch as a spare.
