Coleman vac containers / totes
bandali
Curious if anyone has found a replacement for the Coleman vacuum containers or totes.
I have several blue Recycle totes, and curiously enough 1 (and only one) seems to be a perfect replacement. The coleman totes are 17"x20.5"x12" and the recycle tote (that fit) is 17"x22"x12".
I ordered item# 240771 (recycle tote) from Global Industrial but it was 13" high and didn't work.
Basically the height has to be 12" and the length/width can vary somewhat.
Anybody had any luck?
I made some for the Doyle combo vacs out of cheap cutting boards from Sam's and stainless steel deck screws.
replacing container? I would think those things would out last even the concrete slab. What i found easy to do was put garbage bags over the containers. easy clean up even with shampoo vac that has water/moisture.
