Over the last week I started having issues with finding a wet area on the cement on the backside of the Coleman Hanna power pack. Wasn’t a lot of water and was able to track in down to the overflow pipe on the backside mixing tank. I did notice that the pre-soak chemical tank was at a higher level than normal. I pulled the hydrometer off the pre-soak to bring home so I can use my vise to hold it while rebuilding it, assuming that was the issue. Before leaving I lowered the chemical mixture roughly an inch below the overflow hole. It was a busy day today at the wash. When I went to replace the hydrometer back the floor was wet again and the level was back up to the overflow hole. It seems something has failed allowing water to back feed into the pre-soak chemical tank. The 5 gallon bucket is not overflowing/backfilling, so the foot valve is good. It is filling up to the overflow drain hole and positive it has to be back feeding due to the fact the water inlet was capped while the hydrometer was being repaired. Where should I start to troubleshoot this? What could the problem possibly be? I included a picture of the capped water discharge where the hydrometer is supposed to be, but hard to see the water level up to the overflow. TIA for any input to get the issue resolved.
