Coin Meter Box
DJGall
Dirty Dawg
Not sure if I am supposed to post here or not...but, I need a used/cheap coin meter box. I'm building my own "compressed air vending station"- using a 120v solenoid valve, vacuum timer, equipment room air compressor, and a coin validator to signal the vacuum timer (relay). All I need is a used/cheap coin meter box.
Thanks!
You might just go to Lowes and get an electrical box and paint it. Put an alarm sensor in it or good locks. I used an old Laural Vendor.
Cheap is as cheap does. Security is likely your main concern. I would check with major suppliers of this item. Nat. Pride, Kleen rite, Etowah. FWIW Etowah had one of theleast expensive boxes, likely because it was smaller for me to ad a Bill acceptor to my Bays. To house what you need , you can use the samll time box as well. But of course, make sure you have enough room for all the quarters.
