Cleaning is relatively easy, but also complicated. Part of the problem is that you have to know what is on it in order to select the right cleaning chemical. I've used muratic acid with sometimes good results. All you need is a small pump, a 30 gallon plastic trash can, and a gallon of muratic, which you can get at most hardware and pool stores. I mix 1/2 gallon to about 20 gallons of water and have the pump run it through the membrane. Take both reject and permeate hoses off the menbrane housing, and run them back to the trash can. Let it run for 20-30 minutes, then fill the trash can with water(RO preferred) and flush. It does buy you some time. This only works if you have something on the membrane that muratic dissolves.
