I'll try to be brief.
Cat 530 with a washed out head. Checked new heads or new 530, yikes very pricey. Found a local guy on Craigslist who just did a refurb and has 5 530's for sale at $100 each. I bought 3. Replaced old pump and used replacement has bad valves. Installed used pump #2 and still have valve issues. Replaced valves and everything is good. 3 weeks later the breaker trips. Reset the breaker and start the pump manually with the motor contactor and the motor has a low pitched hum and starts smoking. Unhook the belts and the motor runs fine. Install new spare motor and it makes a funny noise and the pump will only put out 900psi. It's been running for two days now to get me through the weekend but I'm worried about the motor. The pump seems to turn freely but it seems it might be putting too much load on the motor. Anyone seen this before? I don't want to burn up a new motor if it is a pump issue. If it's the pump, where to start troubleshooting?
