Blame it on the check valve
chaz
A $30 check valve managed to shut down my auto for over 24 hours. I had the part on the shelf…but it wasn’t the first suspect. Hi amp draws on driver side…tripping breakers…so yeah we spent plenty of time and money on a motor. Lesson learned start with the cheap and easy stuff
I know the feeling, I destroyed a brand new Cat 630 outlet manifold the other day because the regulator was jammed. It ran great until I let go of the trigger, then I heard the o-rings blow out through the brick walls.
