Bay Walls
Wash Concepts
Can anyone recomend a good paint for bay walls that are K-lite?(not sure if the spelling is correct!) We have tried all sorts of different wall prepping and paint and are still unhappy with the results.
I used devour oil based epoxy. Prepped with the recomended block sealer. Must h/p wash with heat and acid cleaner to get completely clean. Prepping is the secret. Have since used latex epoxy. Latex epoxy not as good.
The only place we paint is above 8 feet & we use Columbia 2 part latex epoxy. It worked out better for us than Sherwin Williams oil based epoxy. Your climate may require a slightly different paint. We are in North Dakota.
