Automatic Door Problem
schmj4910
I recently purchased a Laserwsah 4000 carwash in a cold weather region, and am having a problem with getting the automatic doors to work properly.
When programmed to open or close for either time or temp (not both at the same time), the doors function perfectly, but when I turn both functions on at the same time, the time control always overrides the temp control, regardless of the outside temperature, which means the doors would stay open all day, even if it's cold outside. Is this normal for a Laserwash, or is there another setting I need to adjust that I'm missing? I also have a WW High Velocity in another bay, which I know is basically a clone of the L4000, and those doors work just fine.
Thanks!
That is a typical 4000 you can use one or the other but not both. PDQ has known about this for atleast 10 years, and its not a priority to them.
