pump chatters when run normally. connecting a hose and spray gun assy to regulator ( eliminating downstream problem) did not change chatter. connecting garden hose to inlet smooths it out. Reconnect inlet plumbing. works ok for a bit then chatters again. cleaned valves numerous times. took head off. no cracks or holes in seals. pistons look ok. looked at arimitsu video but seals seem to be different than mine. mine has 2 seals that fit together after i remove retainer then there are 2 brass washer type things; one thin and one thicker. there is another seal in a groove inside seal retainer and that looks ok too.
i thought it was a water feed issue but that seems to be fine after removing all inlet plumbing, cleaning it all out thoroughly and verified flow from gravity tank to pump. tried a different regulator; no change. weird thing is it will work ok for awhile ( a week sometimes) then chatter again but cold water garden hose feed always smooths it out totally.
the pump does see some hot water for a day at a time when i turn the temp up to 140f to decontaminate boats for the DCR. could this have damaged seals in a way that i can't see?
I'm stumped. Any ideas? Try a new seal kit? I'm about to load the parts cannon!!
