Replacing 2 of the 3 pumps at the second wash we have acquired. Put it back same as the old failed pump, but not sure this is the best setup? Each pump is fed on both sides of the head. the right hand side is fed by a tank labled Hot water that is fed from a residential water heater. the tank is not insulated and we don't have the gas turned on so there currently is no hot water, but want to plumb it so we can add it when we can. the other side is fed cold water, controlled by a solenoid valve. On the cold side, there are chemical lines for soap and wax that mix prior to being delivered by the HP pump. There is another chemical line on the "hot" water side but now I cant remember what it is, and then Presoak/tire cleaner is delivered by a low pressure pump just before the boom swivel. there is a 'spot free rinse" on the selector knob, but no RO sytem in the equipment room. Plan to add that. I have read advice on here not to plumb to both sides of the head, but not sure how I can do it differently. Including a photo for reference.
