I’d soak it in a solution of beach and water - probably start on the weaker side and work up if needed. Let it soak for maybe 15 minutes, then scrub it with a stiff brush, then power wash down the drain.Our IBA floor under the dryers is extremely slippery due to algae growing on the cement. Any suggestions as to how to remove it?
We've tried CLR, Scale Away, citrus cleaners... nothing seems to work too well. Any suggestions before my staff and I slip and crack our melon? Thanks!
I spray mine 50/50 bleach and walk away, I’ve never had to scrub it. i also put out around 4 or 5 chlorine tablets in the corners and that helpsOur IBA floor under the dryers is extremely slippery due to algae growing on the cement. Any suggestions as to how to remove it?
Same. Spray it toward the end of the day and leave it, and the next day it'll be dead and will wash off easily. If it's really bad, pressure-wash the bulk of it off, then spray it with bleach.I spray mine 50/50 bleach and walk away, I’ve never had to scrub it.
Algae loves to grow in the car wash environment, wet all the time, chemicals.
I’m not sure that there is an ingredient in soap that promotes algae growth, but I think the higher pH keeps it from growing. Maybe what was on your floor was just from the generally wet environment, and your new soap kept it from forming. Just a guess - damp environments that do not come in contact with any detergent seem to encourage the growth.I used to have algae growth on my SS bay floors. At some point I switched soaps and I no longer have an issue. Does anyone know what is in the soap that promotes the algae growth? Based on my experience it seems to be an issue that can be mostly eliminated. I just don’t know what change I made to control the problem!
Greg, how long does the algaecide last after a treatment? For me, bleach at a 50/50 mix with water completely kills the stuff and it takes a couple months for it to come back.
Hey, Greg, we are the same testing products. I am trying Moss Be Gone from Quest. I've been using it in my automatic bays for the past few months and just spray it on. The algae will turn brown and goes away in a few days. It does appear to have some residual.I'm still in the early stages of testing guys, things are looking good at about the 30 day mark. I was having to re-treat with bleach every couple of weeks in spots that stayed pretty wet and didn't get much sun. I guess it depends on how busy the place is and how wet the area stays. What caught my attention is even the SS bay floors are looking cleaner than previous Summers. What I thought was just general dirt must have actually been mildew.
Randy, Wet and forget has the same active ingredient as this. It's just less concentrated, I think it is around 10% where the pool algaecide in the link above is 50%.. These two quarts can mix up 16 gallons total of solution at a final cost of around 2.50 per gallon, roughly the same cost as 6% bleach diluted with water I guess .
Again, it's not magic and the green doesn't disappear before your eyes like bleach can do. But just another tool that is potentially a little easier to use(non corrosive neutral ph) and hopefully longer acting. It's nice to spray something overhead without worrying what clothes you're wearing too. I sprayed it on the upper parts of my cloth units which actually had moss growing on the very tops. I rinsed everything off, and re applied the product to hopefully retard future growth. I'll try to report back in a Month or so.
It's a product that has been in Quest's product line for a while and I just using it. It seems to work well and not that expensive
