Dema Tip broke off and half of the tip remains inside the injector head. Anyone have experience removing them? Tried a pointy blade (carefully) but it would not grab the piece.
Can you use a regular drill bit from the other end and twist with your hand, should grab it and thread it out. Or a left hand drill bit from the top or an ez out for that size.
Sometimes it is just best to replace them because when you start jamming things through them they get bored out but little pipe cleaner that have a metal wire in the center work pretty good
