Ryko SoftGloss Treadle
DiamondWash
Has anybody moddified the treadle system for the SoftGloss such as: pressure pads, photoeyes or a new designed treadle system? I wish Ryko could make a new design like PDQ "no treadle" design reason is I had a tilt switch go out and what's worse the bolts that hold the cover over it started to spin I got 1 bolt out the other broke off flush with concrete. I know Ryko Mfg is "now" watching this forum I wish we could work together on a new design I would be willing to use our wash to work with them.
I have switched over many Rykos that used the treadle to a pressure pad. Get the wide ones and they will work fine. If you need a short time fix for your treadles now you can run a jumper wire on the PLC from the left and right treadle switch inputs so that if one is working it sends the signal to both so the PLC will start the wash.
I have to repair the treadle base for my softgloss xs (bolts have rusted and pulled out), saw this post, and like the idea of tossing the treadle / mercury switches with a fully enclosed pressure switch. Kleen-rite carry the Recora pressure plates.
Do you have a recommendation for a make / model / size pressure switch?
Thanks
Steve, to upgrade an older machine to use photoeye bayplate, you would need 3 kits. 28586-001, -002 and -003. If the machine is an FX2N, you will need program 25695-002 rev - or later. If it's an FX3U, you would need 27650-006 rev - or later. We used to offer a pressure switch treadle retrokit, however the photoeyes were more reliable.
I think its about a $2k upgrade to photoeyes through Dustin @ Astromatic. Its on my list of things to do in the slow season this winter
You could update with a pressure plate for under $300. They are more reliable than photo eyes IMO.
Thanks for the reply.
I haven't seen any installed so have a couple of follow ups:
Is there a make/model of pressure plate you've had more success with?
Would you recommend the ramps (or can i get by with my current treadle stops?
As much as I enjoy kneeling at the base of my softgloss, I'd like to do it right the first time :)
My retrofits were on older friction machine and also a Monarch 2 touchless. I am not sure of the exact size of the area that the front tires sit on. I would estimate that you will need them to be at least 10 inches by 24 inches and possibly 32 inches. Get ones that will cover the entire area of the front tire pad area. one on each side. Recora or London Mat both sold by Kleenrite. I have had good luck with both. you can by them with a ramp built in. Looks like you will have to spend between $240 TO $300 each. I have been using 10 x 24 for my setup.
