Part identification help
Looking for help to identify a part that is used to fill the soap in a Coleman assembly.
In the picture is the "float switch" that fills the tank, and splices in the soap. It is akin to the toilet bowl filler at my house.
I believe I need to replace it since the pressure coming out of it is low; however, I cannot find this assembly at my local Kleenrite.
Thanks as always.
That's a hydrominder.
Start by making sure the screen is clean and not clogged up restricting flow.
You will need to shut water supply off before.
