Graffiti Removal tips or tricks
Keno
Someone did some graffiti near a vac. Any help on best way to completely remove?
Home Depot sells goof off graffiti remover in a Aerosal Can the Professional strength works very good with a nylon brush and pressure washer or water hose, May take 2-3 times but you can get all that off be careful not to let it sit on the stainless on vacuum as it will turn colors.
let it sit scrub wash off and repeat i have used it alot
Thanks for the suggestions, I will try it out, we tried the goof off, but still could see some remnants.
