Lets Talk Wall Cleaning.....Do the New HF free chemIcals really work?
MaintenceTech9
I have fiberglass and pvc panels and am looking for a cleaning solution that will cut some of the scrubbing time when getting my walls clean. Suggestions?
I keep Quest's SAW on hand. It works pretty good but you have to use it stronger than HF-based Wall cleaner so it's a good bit more expensive to use. SAW actually works better on some things like alkaline scale than HF does. But I still find myself using their HF based product at times (Aluminate).I'm trying to keep the walls clean so that the weaker solutions of either product are effective. Arcadian has one called C3.
I like low fume Muratic acid diluted with 2 to 3 parts water. Works good for me and pretty low cost.
