Big PSI difference at pump when trigger pulled.
carlmorris321
Hello all,
I just got a poor Google Review about my pressure being lower than other self-serve car washes so I figured I better reach out to other owners. I noticed that when the high pressure is running on my newest CAT 310 it reads 1100 PSI and then drops to 1050 when the trigger is pulled. However on a few of my older CAT 310's the pressure at the pump reads 1200PSI but then when the trigger is pulled it drops down to 800 or 900 PSI. I just replaced the seals on one of them and it only gained me about 50 psi so the range is 1200 trigger loose and 950 trigger pulled. Why so much difference from trigger pulled to trigger loose? I also changed my unloader and pressure gauge to make sure they were fine. The valves all worked. I would like the pressure in all the bays at 1050 if possible.
Hello all,
I set my pressures when the trigger is being pulled because that's what counts.
You may have bad pressure regulators (bypass) if its too high when In idle. My 310s usually idle at about 150 to 200 psi. My guess is you're using weep guns so your regulators may not be unloading because there's not enough back pressure (and thats ok as long as desired pressure is being achived for customers) Randy has said he uses a tennis ball to keep the trigger pulled when he sets it, I use my wife 😀. (She's awesome)
Yeah, I use a spring clamp to keep the trigger pulled. Probably should find a wife...lol It sounds like you use a weep gun as well but instead of measuring unloading pressure, measure the idle pressure further along the line. I would imagine my idle pressure is about 150psi as well (My pressure gauge sits right above the regulator so it doesn't measure idle pressure...). I checked out that other forum and saw someone mentioned the tip. I will check that out tomorrow.
I am still learning my terminology here...I don't actually use an unloader. I use a pressure relief valve that bypasses outlet water when the trigger is released and sends it back to the pump. The pressure relief valve works as a pressure regulator essentially. My pressure gauge sits on top of this valve. Also I don't use a weep system that sends a constant trickle when the pump is off. Just a weep gun that sprays low pressure when the trigger isn't pulled.
I try to start with simple stuff:
worn nozzle or different nozzle size?
belt slippage?
inlet restrictions(usually results in pulsation)?
water escaping to the weep system due to a bad weep check valve on that bay ?
I know you said you inspected the valves but worn valves can cause lower pressures. Is this an old pump on the busiest bay?
I've also had unusual restrictions between the pump discharge and nozzle tip- small plumbing, etc. A few years ago I had a strange drop in pressure on one bay and actually had to replace the HP hose to the bay to get the pressure back up. If you can swap hoses in the equipment room to flow water to another bay this will allow you to test for that.
The heads are fine. No pulsating or anything like that. I think part of the problem was one of my pressure gauges was actually bad. I replaced the seals and it looked like I only gained 50psi. I replaced the gauge and now it reads I gained 150psi. All the bays are 1050 now. One just needed new seals. The other bay needed a new tip. Thanks for the help!
So I have a similar issue with two CAT310 pumps. I replaced the valves and seals. Pumps now work great in washdown mode and without the handle pulled. In talking with CAT tech support they said the issue definitely sounds as if the pump is being starved for water flow. I then traced all connections to the water inlet on the pump (bottom openings on the 310). I found a fuse was the issue in the control box. I have KR pump stands and the high voltage to low voltage transformer has a busman fuse that went bad which in turn did not tell the solenoid that controls HP water, HP soap, and HP Wax flow from holding tanks to the pumps to open. If you have tanks for your HP functions see if there is a fuse or issue with electricity to a solenoid (or a bad solenoid) that controls that flow.
This may be a dumb question, but why in the world would there be a solenoid between the holding tank and the 310 head? I understand a solenoid being inline for soap and wax injection but one that completely stops water flow to the head is baffling to me.
Good question. The reason we have a holding tank for rinse water is to have the ability to easily add hot water as an option. The hot water would go into the tank and you can add a heating element to keep it hot. We have not added hot water at this time but system was setup for it to be added in future if deemed necessary or helpful.
Our automatic uses hot water from a dedicated tankless hot water system.
I would never recommend a solenoid there. It's a sure-fire way to cook a pump if for any reason that solenoid doesn't open.
Hello all,
Would i try to get the pressure up yes. I run around 1050 to 1100 psi with trigger pulled on 2506 or 2507 tips. But the first thing i think of is when i have people complain about low pressure is, were they pulling the trigger? 9/10 times its no they were not. Thats why when im on site and see someone on HP with the trigger not pulled i tell them if you pull the trigger on the gun youll get alot more flow. They look amazed when they pull the trigger. I have signage in the bay that says to pull trigger to get hp but hey who reads those.
One way to reduce any negative feedback in public domain is to have a sign on building and in ALL equipment that says
Any issues call or text (your name) at (your number). If you have space we add that everything is run by computers and high tech, sometimes things can go sideways unexpectedly but we try to make things right
We have the longer text on the building signs and the first sentence on all equipment. Helps us learn of issues quicker and make things right with the customer. Goes a very long way in positive direction
