HighOctane
I’ve been blowing through the cheap harbor freight ones ($500) roughly once a year. Looking for a solid compressor that I won’t have to replace.
It all depends on how much air you really need. I have a 4 bay shelf Serve and I need air for my foam brush system, I only have one Flo-jet pump and use air to make it foam. So I don't require a lot of air. So I use a 20 gallon air compressor. Back in 1995 on the night before I was due to go on vacation my air compressor died. All I could find was a 20 gallon Sanborn. I figured that I'd use it until it died. That air compressor is still running today. In that time I had to replace the start switch in the motor and replace the pressure switch. About a year ago I decided to retire the Sanborn and replaced it with a 20 gallon Industrial Air https://www.ruralking.com/industrial-air-compressor-1-6hp-horz-20-gal-v-twin it seems to be working ok. What problems are you having with the Harbor Freight air compressor? A oil less air compressor won't hold up at a car wash. You want a air compressor to run slow, it's the heat that destroys the air compressor.I’ve been blowing through the cheap harbor freight ones ($500) roughly once a year. Looking for a solid compressor that I won’t have to replace.
When I bought my first car wash I needed a compressor and was on a tight budget. I went to Harbor Freight with a 20% off coupon and bought a 21 gallon compressor thinking I'd replace it in a few years. At the 10 year mark it was time to rotate it out and I replaced it with another new Harbor Freight compressor, 10 years later I rotated that one out for a third, that was last year (they now make a 20 gallon.) All of my washes from a 6 bay to a busy 3 bay use the same compressor and I always keep a brand new one at home to break in and as an emergency backup. The only failure I've had was a reed set that cost me less than $15 to replace.I’ve been blowing through the cheap harbor freight ones ($500) roughly once a year. Looking for a solid compressor that I won’t have to replace.
Which model air compressor are you using from Harbor Freight Ed?When I bought my first car wash I needed a compressor and was on a tight budget. I went to Harbor Freight with a 20% off coupon and bought a 21 gallon compressor thinking I'd replace it in a few years. At the 10 year mark it was time to rotate it out and I replaced it with another new Harbor Freight compressor, 10 years later I rotated that one out for a third, that was last year (they now make a 20 gallon.) All of my washes from a 6 bay to a busy 3 bay use the same compressor and I always keep a brand new one at home to break in and as an emergency backup. The only failure I've had was a reed set that cost me less than $15 to replace.
I'm kind of surprised that those air compressors would last that long. A lot of the box store air compressors are made by MAT industries and private labeled.
Several times I've come into the equipment rooms where an air leak developed between visits and its obviously been running for hours if not a day or two continuously and I've just drained the water and oil and it keeps going. I'm not pro-Harbor Freight by any means, I was a Snap-on, Mac tool guy for some time in the past, but when I started noticing they were slapping their stickers on the exact same specialty tools like an automotive radiator pressure tester as HF was selling, I became less brand loyal and more 'what makes financial sense while maintaining a risk adverse posture.' I'm able to respond to a compressor failure inside of an hour by keeping a spare at home and I know it's working by checking the cameras when my customers use the low pressure functions. By no means am I implying this is the 'right way' to do it, just sharing what's worked for me.I'm kind of surprised that those air compressors would last that long. A lot of the box store air compressors are made by MAT industries and private labeled.
A 2 bay self serve car wash isn't going to need a lot of air, try the compressor Ed is using from Harbor FreightThis topic has great timing. I am new to the business and getting ready to reopen a two bay SS. One of the last items I need is a new air compressor. Any recommendations on an air compressor? Single phase electric.
