Petit 360i Extra Tall
HeyVern
Anybody running the extra tall Pettit yet? Getting ready to install my second machine and debating whether to go with the extra tall.
Blanco
Your customers will use your standard height more. They will get a better dry being that the dryers won't be 10ft off the ground to accommodate for the machine clearance height. Something to think about.
HeyVern
That is the hesitation I have about going with the extra tall. I think I wash enough full size trucks and SUVs that I can send those through the tall and cars through the standard. I have a customer with 5 tall vans that would use it for sure. I don't know how many others are around town that would use it.
Blanco
If your two auto bays are identical size and you're running enough cars to justify a second machine I would go standard height. Who ever pulls in goes to the one with the fewer cars in line. It does not matter. If one machine is down just tap the button on your phone to shut the power to your pay station off and close it down for repairs. That will send everyone through the other identical machine. Your always open unless you have really bad luck lol
I have a location with an extended height machine. Not a petit. The bay I installed it in was 60'L x 18'W x 16' H. It sits next to my smaller touchless bay and it used to be a drive thru semi/bus wash. I wanted to utilize the size of the bay to the fullest and also give a soft cloth alternative. It's been only 3 months since machine was installed and I am very happy with my decision but from what I see is it is mostly used by vehicles under 8'. If that bay was identical dimensions to my touchless bay then I would have installed the same machine next door.
The larger than 8' vehicles are rare. They actually cost more to wash too since they require more soap and water. You sacrifice giving the best dry to the 95% of normal size vehicles only to accommodate the 5% that only buy the basic wash because usually there company vans anyway and they dont care.
First time I went through an extended height with my F350 I noticed the dryers immediately and I drive a big truck. I willl say with my machine, the drying agent I use, and extra dryers certainly help a lot compared to the one I went through when I was looking.
You should find one and go through it. Im sure that will help you make your decision.
Blanco
Also forgot to mention since your doing a touchless the penetration from your overhead spray bar will be much weaker being it’s almost 2 ft higher. So you also sacrifice wash quality. How significant it is you would have to go through one to find out.
HeyVern
I'd like to go through one, I'll have to check with Petit to find out if where to find one.
