I get my high and low pH from local distributor who worked with Warsaw Chemical to formulate something just for them. But for triple foam and tire cleaner I go through JBS because the product is comparable but more affordable. JBS is great to deal with and a lot of the product is available from Kleen-Rite and almost all of it is available from Windtrax. Windtrax has a shipping deal get a pallet free shipping. Kleen-Rite has shipping deals too.We are in the process of starting up our first IBA. I don’t where to start on the soap/chemical department! What kind do you use? Through a distributor or not? What do I need to know to make the best choice?
Although I have seen some pretty good touchless machines I have yet to see one that I think would pass the white glove test. Maybe on some cars and some types of dirt at certain times of the year. If they could pass the test then there probably would be not as much talk about some of us looking into friction machines.Bring a white towel and wipe the car after the wash. There should be NO dirt on the towel.
I've seen the white glove test passed, but the machine and building is usually rotting away because of the strong acid with which they're cleaning the cars.Although I have seen some pretty good touchless machines I have yet to see one that I think would pass the white glove test. Maybe on some cars and some types of dirt at certain times of the year. If they could pass the test then there probably would be not as much talk about some of us looking into friction machines.
I would follow Tom Petit's recommendation on a distributor. They know what they are talking about and will steer you right.Ok...my apologies for not giving enough information! South Dakota. They do salt our roads here now and we have dirt and dust. And pollen. Lots of it. Bugs hit the windows like a hard rain in summer. We use soap and wax and foam brush soap from dultmeiers that is turtle wax brand. (The soap is turtle wax...I haven’t had to order the other products yet so I’m not sure if they are the same.) water is hard but we do use a softener for wax. Hot water wash. Cold rinse.
The IBA is coming from Petit. We are installing it ourselves. I did check in with them today and they said they would connect us with a distributor.
What brand of chemicals are you feeding that thingWell you are all welcome to come and visit my wash. It passes the white glove test and does it with no harsh chemicals. They are safe on all surfaces.
Currently it’s a proprietary blend. I’ll check with my supplier and see if he’s ready to go public. This stuff works.What brand of chemicals are you feeding that thing
Proprietary blend or private lable I am interested in this top secret soapCurrently it’s a proprietary blend. I’ll check with my supplier and see if he’s ready to go public. This stuff works.
Mac, don't you run Istobal friction? Id say nearly all frictions pass white glove.Currently it’s a proprietary blend. I’ll check with my supplier and see if he’s ready to go public. This stuff works.
