Touch Select 2000 bay door seems stuck in programming mode
Spwaycarwash
It’s a touch select 2000 bay door by D&H with touch pads not the rotary switch and the screen just sits with a zero on the far right side. No change when quarters or cash are put in it. I’ve looked in the manual and tried to exit programming mode like it says but it won’t do it
if im reading it correctly there is a spot in the troubleshooting section for this but I must admit im not knowledgeable enough to really understand what it’s saying the issue could be. I’ll post a picture of it but it says “a bad push to start or push to stop button on the pump station” which must have something to do with the actual pump inside the equipment room. I also posted a pic of the door just so you can see exactly which model I’m talking about but the picture does not show what the screen shows currently
anyone ever dealt with this?
Try unplugging the wires to the buttons in the pump room for that bay.
