TM5J to LED6 Help!
JoshsWashes
Indiana
I just tried to update my TM5's to LED6's so I could also install crypto pay in count up mode. It was a disaster to say the least.
Now when money is put into bay 1 it comes on and so does bay 3 and vice versa. Bay 2 was operating flawlessly.
I wired and verified a hundred times but with no luck. All 3 bays run just fine when I reinstalled the TM5's.
any ideas?
My first thought would be to check the phases. Does each bay have its own transformer, and do all the bays have the common side interconnected somewhere? Mixed phases can cause weird problems with Dixmor timers (although I've never seen it make other bays come on).
If you have a volt meter, check across the transformer "hot" between bays 1 and 2. It should read zero volts. Same with 2 and 3, etc.
