Sonny's vs. Motor City
crkiser
What are your pro's and con's with Sonny's and Motor City? (Or anyone else you suggest) Good experiences, bad? Customer service, quality, start up support, involvement ect. We have quotes from each and trying to decide. (Building 100' tunnel) Thanks in advance!
MC3033
Midwest
Sonnys wins in simplicity, parts, customer service and overall support.
Motor city typically uses more components in order to give you more control over your equipment. I would give motor city a slight edge in quality (engineering is robust) but they use more components leading to more overall issues.
I would highly recommend you either mix and match or go with whoever can get you better local support
BenBranam
San Antonio Texas
If you want a smaller footprint that will do the same amount of cars, AutoBrite is a newcomer and we are trying to change the way tunnels are done. Make them smaller and do the same amount of cars with a different design on the building.
Check us out at AutoBriteCo.com
We use a belt instead of a trolly system which generally makes it safer and lasts longer. Everything inside is stainless steel so it won't start looking old and rotten and will last longer. And it's a modular system we can tweak to meet your needs. We also use all the up-to-date tech inside the tunnel to get a great wash in a shorter distance and more cars through that tunnel than others.
Axxlrod
Car Washer
CA
Where is AutoBrite equipment manufactured?
