Seaking Air Distribution Manifold Block PN339 for a newer Belanger Vector
kendal
Hi,
Belanger and their supplier is no longer making a part we need for a 9 year old Vector Wash. We have been told the only option is to buy a new wash! I am hoping someone can help us out.
We are looking for a 1VALVE-PN339 Air Distriution Manifold Block for new style Belanger Vector.
Looking for new/ used/ salvaged.. anything that will work.
New Washdog
Vermont
Hi,
Do you have a picture? How many ports?
JGinther
Zip-tie engineer
Loveland, CO
I would try calling SMC and see for sure if thats the case. And besides, you should be able to get just the individual valve insert - not need the entire block. Is only one valve giving you problems?
kendal
Thanks, just checked with SMC, they don't have it. It's the back end that's the issue not one valve.
It's just solenoids on a fancy block setup. You should be able to recreate that with normally open, normally closed and 3-way valves on a tree for a few hundred bucks.
Jsshac
Belanger still list it I ran the part number and it came up
If true , that would mark Belanger off theblist for future installs.😰
