pulsatron output hose rupture
Sparkleclean
New hampshire
We use pulsatron pumps in a belanger setup (pumps, manifold, etc, all belanger O.E.M.) and all of a sudden i have one pump that is rupturing he output hose. Its somehow letting too much pressure into it and starts as a bubble then bursts. Its happened 3 times in 2 weeks. Does anyone have any idea why this would be happening? They pump chemical up about 18" into injectors installed into the water hoses carrying the mix out to the bay for that piece of equipment.
Coukd that injector be clogged and allowing pressure to build behind it?
John J Spokas
Naperville, IL
What machine is it connected to?
Sparkleclean
New hampshire
What do you mean what machine is it connected to?? It sucks chems from a drum below it and pumps it up to the injector going directly into the water line going out to the tunnel equipment. The equipment it is supplying is a regular arch. So no back pressure there.
Your injector may have a check valve that's stuck, or it could be clogged. Are you using non-reinforced clear PVC/vinyl tube?
