1 1carwash1 Member Joined Sep 9, 2008 Messages 114 Reaction score 1 Points 18 Location east japip Aug 5, 2020 #1 Any ideas on how to mount a Dixmor horn. Don’t want to leave it dangling in the meter box. thanks
MEP001 Well-known member Joined Aug 30, 2007 Messages 12,906 Reaction score 1,010 Points 113 Location Texas Aug 5, 2020 #2 I use a zip tie with the mounting ring, zip it around the horn, and put the ring on one of the studs with a nut.
OurTown Well-known member Joined Nov 8, 2017 Messages 1,865 Reaction score 242 Points 63 Location Dayton, Ohio Aug 5, 2020 #3 We have brackets on the ones in our bays and tried to find some but for our vac project couldn't. Ended up doing exactly what Mep said to do but the brackets would be great.
MEP001 Well-known member Joined Aug 30, 2007 Messages 12,906 Reaction score 1,010 Points 113 Location Texas Aug 5, 2020 #4
1 1carwash1 Member Joined Sep 9, 2008 Messages 114 Reaction score 1 Points 18 Location east japip Aug 6, 2020 #5 Mep, what spade connector are you using for the terminal block?
E Earl Weiss Well-known member Joined Aug 31, 2007 Messages 5,499 Reaction score 189 Points 63 Aug 6, 2020 #6 I think some of mine use a 2 sided sticky mounting tape.
1 1carwash1 Member Joined Sep 9, 2008 Messages 114 Reaction score 1 Points 18 Location east japip Aug 6, 2020 #7 MEP001 said: View attachment 1966 Click to expand... Mep, what size and make are the connectors on the terminal block?
MEP001 Well-known member Joined Aug 30, 2007 Messages 12,906 Reaction score 1,010 Points 113 Location Texas Aug 6, 2020 #8 They're both 1/4" wide spade terminals, but any spade that fits a #6 screw will work. https://www.mouser.com/ProductDetail/517-2232
J Jsshac Member Joined Oct 29, 2019 Messages 53 Reaction score 15 Points 8 Aug 8, 2020 #9 Ginsan sells last coin alert brackets
R Randy Well-known member Joined Sep 5, 2007 Messages 3,954 Reaction score 439 Points 83 Aug 8, 2020 #10 Why don't you just make them yourself. A piece of thin aluminum and a hole saw and your done. Simple
