Has anyone ever thought of using windshield washer fluid to keep the lines from freezing? Any ideas on how to do it?
For about 5 years, my FB winterizer works with standard foam
soap and windshield washer fluid.
The system uses an Idec Smartrelay, programmed to wait for the FB input from each individual bay.
IF? the temp output #2 from the Weepmizer is ON,
AND? the FB input is turned ON, the program waits for the FB input to go OFF.
Once the FB input goes OFF, the Smartrelay then energizes the ?anti-freeze" solenoid for that bay. The Smartrelay?s output is timed to allow the washer fluid to be pumped to the brush?anywhere from 8 seconds for the closest bay to 30 seconds for the far bays.
The program also energizes ALL of the Smartrelay?s outputs when the temperature drops to the setpoint of the Weepmizer for more than 5 minutes. This reduces consumption should the temperature hover at the setpoint. I believe I have the Weepmizer?s output #2 setpoint programmed to 35 degrees. The Weepmizer?s output #2 also turns on my trough blower and warm water circulator keeping the trough nice and toasty.
The system required a NC solenoid, a tee fitting, some ?? poly tubing and a check valve for each bay, plus a Flojet pump and pressure regulator set to 30psi. I draw the washer fluid from a 15 gallon drum. I already had the Weepmizer. The washer fluid injects into the FB liquid lines just before the tubes leave the equipment room.
I?ve had only 2 or 3 brushes freeze in the 5 years the system has been in operation. I use an average of 30 gallons of washer fluid per season?from Sam?s Club?about $1/gal.
It works great?much better than the original air-blow-out system or the water weep system (which resulted in very large icicles hanging from the brushes). And, I get great foam year round using the same foam brush juice and ratio.
