Metal pipe
Bricks
I was looking in the attic the other day and at the end of the HP hose for bay 1 there is a bulge in it with a single drop of water on it.
This hose has to be 20’ long. Should I take it off and go have a new end put on it?…I think there’s enough slack. Or buy the $200 hose?
Or is there any way to hard plumb up the wall and over close to where the rubber goes. It’s just getting so expensive buying hoses. Thanks for any advice!!
$200 for a hose? That's insane. $29:
I have a swager to make hoses, and if I can't avoid contact with something that might rub through it I slide a cut piece of 3/4" polybraid over it before I put the fittings on, or I slit the hose lengthwise and just slip it over.
Bricks
Unreal. This forum will be the difference in making my business payment or not. Thank you!
Eric H
Leominster, MA
It looks like 1/2" fittings. I would order it with 3/8" ends and use brass bushings to make it 1/2". The hose is 3/8" ID.
