Machine moves itself
Calgary
Hello,
When the machine is done washing, it comes back for few inches. This makes the machine to move itself from the Home position so the machine automatically moves itself forward for few inches to the home position in about a minute after its done. I noticed the plastic part between the couplings (see pic) is damaged. Would changing the plastic part fixes the problem? Also not sure what caused the plastic to get damaged so bad in the first place.
Tom Thumb
Orlando,Fl
Hello,
Lovejoy coupling wear normal, needs replacing.
Calgary
Thanks guys Im still missing why the machine goes back when it is done washing. Do I need a new gearbox???
Tom Thumb
Orlando,Fl
Hello,
remove cover and move gantry manually, check amount of slack in coupling on both sides passenger and driver.
Calgary
Yes I see quite bit of slack on this passenger side which I think is due to worn out lovejoy. The motor/gearbox start rotating the left side coupling, but the right side doesnt start rotating for 1-2 seconds (or meybe less). Ill go ahead and replace it with a new one and report here if it fixed the issue.
srr5008
Northeast PA
Because of the gaps (from the worn lovejoy) the weight of the gantry has the whole unit rolling backways, taking up that slack when the machine is at rest. Pretty common issue/maintenance with these machines.
Calgary
Update: this alarm67 happens every time the machine doesnt stop at the home position(rolls few inches back due to slack due to damaged insert). So my guess is replacing the insert will fix alarm67. But pls share your experience with me if you have seen this as well?
srr5008
Northeast PA
I have never encountered that alarm in conjunction with a bad love joy.
Calgary
Update: changed the spider insert 2 month ago but its worn out again. Need to figure out whats causing it. Maybe bad bearing. But how do you check?
What if I just stop looking at it? Lol whats the worst thing can happen? Like what if there is no spider insert?
Tom Thumb
Orlando,Fl
You can just let it go and look at replacing the motor and gearbox along with lovejoy and wheel bearings, because now you have a extra load on all units.
Calgary
Well thats not good…although I do have a worn livejoy on the boom for almost 4 years with no problem.
Tom Thumb
Orlando,Fl
If the gearbox is not inline with wheel bearing that will cause the spiders to wear quicker.
Gantry can be raised off rails and supported by 2x4 under frame, idle bearings will be free to check, gearbox will need to moved to check drive bearings.
