zed 9
Hello forum members, two problems i am having with our PDQ LW4000 with virtual treadle.
Problem 1. The width measure front and rear is not recognizing the difference between small cars and bigger cars. Car is loaded into the bay and the spray arch goes full extent to the right and full extent to the left this happens on all passes, low pressure soaps, high pressure, 3 x tri color and the spot free rinse.
Problem 2. when the arch rotates and stops suddenly at each of the 90 deg turns there is a thud noise, the arch rotate gear box is good. Is there some thing like an " electrical brake " incorporated into the electrics that smooths out the sudden stop at each 90 deg turn, or am i missing something else
