Low Pressure System Help
NessaForever
I’m probably overthinking this but wanted to make sure.
I have my air line from compressor going into my filter/regulator on my tire cleaner setup.
Do I tee the air line out of the filter/regulator with one line going to the air solenoids and other line going to the flojet? I am not using a multiplexer for now, just dead heading it.
thanks for the help
Ryancross11
Off your filter T then regulators to air solenoids and flow jet. Most low pressure need separate pressures for chem and air.
Ryancross11
Yes, My presoak runs 80chem/ 40 air. My foam brush runs 38chem/25 air.
NessaForever
makes sense. Thank you. I have a combo filter/regulator so I can use that one for chemical and then get another regulator for air.
Tire cleaner can be run with one regulator tee'd off to the air solenoids and the Flojet, but it's a lot harder to adjust. If you don't have individual adjustments for every line out to the bay, it will be impossible to get a smooth flow.
NessaForever
Thanks. Think I’ll use the filter/regulator combo to control the flojet for chemical solenoids and then tee off and use just a regulator to control the air solenoids. Sounds right?
