Low or no Pressure on soap, however High pressure on Rinse
Nknjeim
Self Serve Carwash with Coleman equipment.
Too many things broke down due to freeze we had last week in Texas...
In one of the bays, I have a low or no pressure on soap (usually high pressure) however high pressure rinse is still working normal.
Anyone can help?
The check valve under the tank is stuck closed.
Nknjeim
Isn’t it the same valve that feed high pressure rinse too?
I am getting soap but no pressure
Rinse is fed by a solenoid. Water for soap comes through the check valve under the tank.
Autowarn
Check for a leak, if it is spurting, it is probably because air is in the line. Check if air is in the line, and check for leaks. It is also a good idea to call for maintenance if the problem is deep in the machine or you don't know what the cause it.
Rfreeman
Ft. Worth
Agree with Mep. I am in Texas as well running 3 JC pump stands and already replaced 3 check valves because they froze and got shot. Along with that you may have replace the seal kit in the pump as well. I had similar problem replaced the check valve then had to replace the seal kit.
