Hey guys,
I'm interested in setting up a simple system (as in "plug and play") to control some things at my wash. I want to reboot my wash select, and activate a dry contact to both reset my auto, and give a free wash.
The simplest idea I can come up with is to use the samsung smart things hub ($70)outlet with their 110V smart things outlet ($40) . This would allow the use of a phone app to control these outlets. Whatever might need rebooting (wash select, etc.) would have to be wired through the outlet and simply turned off and back on. To reset my auto which uses a Normally Open button, I could envision just adding a 110V relay. I would just momentarily turn the outlet on and then back off, cycling the relay and closing the contacts.
Another advantage of the smart things hub is the input sensors could be utilized. They have a water sensor, and and a multipurpose sensor that works as a door sensor or shock sensor.
Is there a simpler/better way to do what I want?
