LED6 Programming
JoshsWashes
Indiana
I am just getting ready to install my cryptopay units in count up so I went and purchased LED6 timers and the programming guide lacks some information. The factory default is $2 for 4 minutes, I want to set it up for $2.00 for 3 minutes and each additional coin 35 seconds? So do I adjust C: to 23 and then add the extra seconds to the bonus time?
Thanks for your help!!
JoshsWashes
Indiana
No, bonus time is for the bonus coin setting, one that when reached you can give either a lump of bonus time or some bonus time per coin when it's reached. You'll set C: to 23 and S: to 008.
http://www.dixmor.com/TIMER PDF/LED6 INSTR.pdf
ok I set the C:23 (3:04) to start and then S:3 Bxxx 9 (bonus starts on coin 9) Bonus time to 35 and then set the bonus to multiple bonus.
Seems to be working as intended!
Now on to the cryptopay install!!
That's correct, sorry, I missed the part that you wanted to give more time per coin after startup or I would've mentioned the multiple bonus part.
JoshsWashes
Indiana
Do you know is there a way to make it land right on 3:00? It's either 2:56 or 3:04 the way it is.
The big Dixmor timers let you set the exact start time, the LED6 is only time per coin.
I'd start it at 3:04 and not worry about it.
