JE Adam vacs & CryptoPay
Eric H
Leominster, MA
561
Can CryptoPay be added to these JE Adams vacuums? There doesn’t seem to be enough space to insert a card, swipe it and remove the card.
I have 21 vacuums on 3 properties that I’m considering adding Crytopay to the vacs. I already have Etowah Valley CC in my SS bays. The thought of replacing all of the vacs to add CC makes me sick but I’d like to add Bill Acceptors some locations and the Acceptors definitely will not fit inside these vacs.
Anyone have an easy/economical solution?
That looks tricky but maybe you can put a spacer under the swiper and mount it under the indicator lights.
https://www.kleen-ritecorp.com/p-62219-cryptopay-mounting-spacer.aspx
I'm not sure why the spacers are so expensive but you could make them with your woodworking tools.
Laurel makes this add on box.
https://www.kleen-ritecorp.com/p-41...unt-box-with-lock-for-credit-card-swiper.aspx
You could have custom doors made that rearrange the timer and coin acceptor to make room for the swiper. You might have to go with a short drop acceptor though adding to the cost. Doyle made some custom doors for us and were only $45 each. I'm not sure if JE Adams will do that or what they cost. Etowah Valley might make them for you too.
