IBA Bay size
lilb93
Coal region of PA.
Thinking of installing an IBA in one of the SS bays. Problem is Bay size 25 X 14. Would anything fit in it??
robert roman
Bob Roman
Clearwater, Florida
About 10 years ago, I saw this done in Florida.
Dealer installed a mounting frame that was bolted to floor and side walls and extended several feet beyond the bay end-walls. It wasn’t pretty.
I can’t remember unit, but dealer handled PDQ and Coleman.
Some roll-overs could fit. For example, Broadway track is only 10’ by 23’ but requires 33’ bay length to accommodate brush rotation.
So, you would need building extensions.
I have installed an Istobal friction M22 in a 25' by 13' bay in Florida. Had a canopy made up that "extended" the roof, mostly just to keep the sun off. Even the factory said it wouldn't fit, but it did.
ToFarGone
Burlington Iowa
Probably not in a way that would look or function right. I was at the same crossroads in 2008. Also you won't be able to wash longer vehicles (for me its a must, 4 door 8 foot bed). If there is anyway to extend your building it would open your options big time. You could get the machine you "want" and have confidence in and not have to go with "what fits".
Put your Laser in the front of the bay, under cover. It will extend out a couple feet while "In Wash", but just for a few seconds at a time. This is what I did.
