I want to add another low pressure selection
Don Sexstone
I am trying to figure out if I should go with an air logic or dosatron low pressure system to add foaming presoak ..... I am pretty new to industry and just looking for suggestions. I appreciate the help.
I'd stay away from Dosatrons. It's a good theory, but you're limited to your water pressure for output to the bays, and I like good pressure on presoak. The Dosatrons are expensive and not very reliable. I'd recommend using a Procon at 100 PSI and build your own, there's not a lot to it. Use individual solenoids, the blocks cost about the same and you'll eventually have to replace the block manifold instead of one solenoid.
Don Sexstone
The Procon goes onto an electric motor.
Don Sexstone
Makes sense I do not mean to be a bother but is there a reference picture out there being used for a self serve bay
