how to clean softtouch rollover in-bay brushes?
washtecnic
Hello,
I have soft foam material brushes for my softtouch rollover in-bay
How can I clean this soft foam material brushes? they tend to get dark with time
Please tell me what product you use to keep them clean
is it a specific product? or I can use any of the products already used to clean the cars?
mario
Mario,
We have the soft foam cloth also. We put 55 full gallon drum between the spinners so the 2 spinners will rub on the drum with the auto not moving, then turn it on and spray wall cleaner on the cloth as it is rubbing on the drum and let it run. Then use a high pressure spray hot water on it. Then reverse the rotation of the spinners and do it again. If you use a high ph soap for washing then try a low ph liguid to clean it. We have not found a magic solution to clean them. They do get cleaner and you will get very wet.
