how to avoid getting grit in my gun tips
coincarwash.ca
Washin cars in the GTA
Toronto, Canada
Sometimes I get a small piece of metal that gets stcuk in my gun tips and causes my weep not to weep properly and I get a freeze up in the bay. Is there some kind of strainer or something I can use to capture the grit before it gets inside the gun?
coincarwash.ca
Toronto, Canada
I believe it is in the city water lines and coming through my weep line into the pump. It always seems to be a small piece of some metal fragment. I was looking at some tips that Kleen-rite has that have strainers that go with them .( a nozzle body ,Strainer ,nozzle and a cap) I thinks it's called a Teejet assembly....Has anyone here ever used one?
pitzerwm
Tri-Cities, WA
It could also be flakes of rust from any galvanized pipes like the gun. But yes any filter would eliminate water supply stuff.
PaulLovesJamie
rural 5 bay SS
Kutztown PA
Yeah, those strainers work well. Just keep a close eye out to be sure that the strainer doesnt get clogged, that'll cause all your bays to freeze. My weep is recycled, the strainer would clog after a month or 2. Since you're on city water its probably not an issue, but I'd glance at teh strainer every day anyway. (Make sure you get one with a clear bowl.)
