A A.Milton Member Joined Jan 19, 2014 Messages 57 Reaction score 2 Points 8 Location AuGres,mi Feb 6, 2020 #1 Foamy brushes in all bays spits product out initially. You have to step back. Then evens out to desired flow? What is causing this forceful start up?
E Earl Weiss Well-known member Joined Aug 31, 2007 Messages 6,184 Reaction score 752 Points 113 Feb 7, 2020 #2 Many Variables. Do you use foam generators? They may need cleaning. What are Pressures set at. If you use flo jets set air to pump at 40 and Air to make foam at 10. Make small air adjustments and see how that works out.
