Roz
- Joined
- Oct 29, 2017
- Messages
- 931
- Reaction score
- 380
- Points
- 63
I’m gonna high jack this thread if thats ok. I’ve been having this exact issue for 2 months !!! I’m at my wits end. I bought 16 new check valves in going away from fluid control. Brand new valves the other day and I’ve busted another flo jet. Kleen rite is sending me more of a different brand. I have tire cleaner bleeding through the pre soak chem line going all the way to the solenoid in the room. AmIs this tied into a bay manifold- presoak, tire clean, etc? I have seen high pressure come back in the lines due to bad check valve and kill the flojet
Yes normally but the hoses looked so-so therefore I just replaced them.I don't remove the hoses from the barbs since they just unclip and pull out of the pump.
Don’t take the wrong way but sometimes tired eyes will install them with the flow the wrong way.I’m gonna high jack this thread if thats ok. I’ve been having this exact issue for 2 months !!! I’m at my wits end. I bought 16 new check valves in going away from fluid control. Brand new valves the other day and I’ve busted another flo jet. Kleen rite is sending me more of a different brand. I have tire cleaner bleeding through the pre soak chem line going all the way to the solenoid in the room. Am
I missing something else? I thought this was simple fix. Am I just getting bad batch of valves or is something in my system causing them to fail?
I always plumb car washes with one check valve at the boom with presoak, tire cleaner, and air lines joined at a cross. In the room I use an air regulator like this one that relieves pressure on the outlet that exceeds the set inlet pressure. If a check valve in the bay fails, the regulators just relieve the pressure and nothing gets damaged.I’m gonna high jack this thread if thats ok. I’ve been having this exact issue for 2 months !!! I’m at my wits end. I bought 16 new check valves in going away from fluid control. Brand new valves the other day and I’ve busted another flo jet. Kleen rite is sending me more of a different brand. I have tire cleaner bleeding through the pre soak chem line going all the way to the solenoid in the room. Am
100 percent agree , no offense taken. But, definitively not the problem. I put my readers on to make sureDon’t take the wrong way but sometimes tired eyes will install them with the flow the wrong way.
We put a additional check valve on the discharge line of the pump, between the floJet pump and the manifold.I’m gonna high jack this thread if thats ok. I’ve been having this exact issue for 2 months !!! I’m at my wits end. I bought 16 new check valves in going away from fluid control. Brand new valves the other day and I’ve busted another flo jet. Kleen rite is sending me more of a different brand. I have tire cleaner bleeding through the pre soak chem line going all the way to the solenoid in the room. Am
The fluid controls is what I’ve always used. That’s what I was leaning towards, trash in the lines. I don’t know what else cause this. I cleaned out the tanks , solenoids etc yesterday. Same issue today. You wouldn’t happen to have a visual of how you set it up in the bay would ya. I have air logics in the equipment room. one manifold in each bay for PS and TC. Obviously 2 air and 2 chem lines for each. Came in this afternoon , same issue after getting it right and testing after changing some more valves yesterday.I always plumb car washes with one check valve at the boom with presoak, tire cleaner, and air lines joined at a cross. In the room I use an air regulator like this one that relieves pressure on the outlet that exceeds the set inlet pressure. If a check valve in the bay fails, the regulators just relieve the pressure and nothing gets damaged.
I use the Fluid Controls 1/4" check valves with Teflon seals and I've had no failures. Maybe you have debris getting down stream and getting caught in them?
I like it,This is at the boom:
Board inside:
The air lines are tee'd out of sight and only one air line runs to the bay.
Im going to do this asap. 16 CVs is a jokeThis is at the boom:
Board inside:
What PSI are your air and product settings? Also we need to set things with the product running in a bay otherwise we can get inaccurate settings. Product should be about 2x air.I’m gonna high jack this thread if thats ok. I’ve been having this exact issue for 2 months !!! I’m at my wits end. I bought 16 new check valves in going away from fluid control. Brand new valves the other day and I’ve busted another flo jet. Kleen rite is sending me more of a different brand. I have tire cleaner bleeding through the pre soak chem line going all the way to the solenoid in the room. Am
Running all low pressure chems at 60 40What PSI are your air and product settings? Also we need to set things with the product running in a bay otherwise we can get inaccurate settings. Product should be about 2x air.
Yes.what is the other check valve you have right of the hp line? Spot free?
Guilty here of doing that before. I always mark big directional arrow on mine with a sharpie where I can easily see it. That way when I get up in the attic I don't need my reading glasses.Don’t take the wrong way but sometimes tired eyes will install them with the flow the wrong way.
What product is this? Non-neutral chemicals play havoc with normal PVC tubing over time. Also the newer waxes can be problematic and cause the tubing to swell. .Problem solved. The 1/2” hoses on the bottom were snug fits so I did not use a clamp on them. Just added clamps and the issue is resolved. Strange
Desalt and Tire Shine are the hardest on the poly lines.Guilty here of doing that before. I always mark big directional arrow on mine with a sharpie where I can easily see it. That way when I get up in the attic I don't need my reading glasses.
