- Joined
- Aug 31, 2007
- Messages
- 6,184
- Reaction score
- 752
- Points
- 113
Coins were not falling into vault. Open meter and coins stacked in tube. Pull out all we can reach and hit clog about 4 inches down with a threaded rod. No Luck. Open vault, naturaly it is the far drop tube. Hit clog from bottom with fish tape. No Luck. It's been below freezing for a week and now it's about 15 degrees. Try to heat clog from top with torch and put flame at bottom of drop tube as well. Clog seems to be about 18" thick based upon how far fish tape goes in.
Some quarters come loose. Put shop vac at tube top in meter box. Can feel air flow at bottom, but clog is still there. More heat with torch at bottom . Now with shop vac on to pull heat thru .
After an hour of repeated heating and jabbing from top and bottom about $30.00 in quarters and ice come out.
Was thinking maybe it would have gone faster if I heated water in the microvave and poured it in to the tube. The torch only seemed to get the surface of the clog.
Any thoughts?
Any thoughts?
