Coleman Hanna super vac 3 lock
Detbjr
Does anyone know how to open the coin door lock with out a key? Got 4 vacs with no coin door key. Drilled out the antidrill ring so far. But I’m not familiar with the latching mechanism so I don’t know which way to turn.
would prefer to do it without getting medieval on it but patience is wearing down. Locksmith not providing much help and not cheap.
is there a standard skeleton key you can get?
photos attached
I just sent you a PM on how to get it open.
Detbjr
No dice so far. If anyone has a picture of the inside and back side of the vault door would be immensely helpful so I can see which way to turn and how deep to grind etc. thanks!
Detbjr
Stroke of luck and I got one open. Success rate improved from there
Detbjr
Followed advice but it only worked on 2 of 3. The first one likely I’m needing a need vault door
Detbjr
The luck was getting the finesse without any practice.
Some of those locks you can just blast through with a drill and it'll just unlock, the high security lock has to be done differently.
