Change CP2120 BElt
Calgary
Hello,
I had to change the belt on one of our CP2120. Last time I didn't loose the pump and kind of forced the new belt on the pulley. This time I loosened the pump, moved it backward a bit and it was much easier to remove the old belt and put the new one. But, how do I put enough tension on the belt? So I pushed the pump toward myself as much as I could and asked my assistant to fasten the screws. I think there should be a better way. Thanks
I usually get it as snug as possible by hand and tighten the pump down. I then roll the belt off and move the pump forward 1/8” or so and force the belt back on. If I’m not happy with the tension, I repeat the process. By forcing, I mean rolling the pulleys to get the belt on, not prying it on with a crow bar.
I use an adjuster mount under the motor, then you only have to loosen the motor bolts and tighten the bolt head on the back.
A long prybar works on a lot of pumps, the kind that's basically a three foot long screwdriver with a slight bend at the end. I'll use it to pry against the crankcase beside the pulley and put the blade against the bolt head which helps make it a one-person job since the prybar against the bolt head also keeps it from turning while I tighten it from the bottom with the other hand. Some stands are set up pretty well to use a claw hammer to hook under the manifold and the head against the front of the stand.
The worst tool I've used was a shovel handle. I was prying and it slipped of and I hit myself in the head with it with just about all my strength and weight. I still sometimes harf to blet thr gomdigl beldom.
see attached for V-belt tension
FWIW, I tighten them far tighter than that. Tightening a new belt I go to almost no deflection at all because they will wear and stretch and fairly soon will be too loose. You're supposed to set it then come back in a month or so and retighten it but no one does.
Calgary
Thanks, how do you "roll the belt off"? By a flat crew driver while turning the pulley? After moving the pump 1/8", don't you need to use a plyer to put the belt back on? I'm trying to find a way to not to use a plyer. What happens if the belt is not 100% under tension? I mean right now the pump works very well with the pressure I always have and no noise. Thanks
Jeeez, get yourself a belt jack and be done with it.
br549ms
Mississippi
Looks like it might work, never used one. But, I would probably loose it and wind up doing like MEP001 says. However, be careful and do not over tighten.
Damoni88
Lake charles la 70605
Same as mep so much easier
Or you could make one....But for $23.00 why waste your time. I wished I would have seen this before making one...I used 2 pieces of 1/2 plywood with a vee notch cut on one end of each piece to fit in the pulleys. Then bolted a turnbuckle in the middle...Works just as good, just not as pretty as the one Randy linked to! Works great! Perfect tension every time and allows you to put a straight edge on the pulley faces to align them while tightening bolts...
Keith Baker
Keith Baker
Omaha, NE.
My pump and motor pulleys are only about 4" apart. I use a piece of 2 by 6 lumber, trim it to make a wedge and drive it in between them at a slight angle. When the pump is tight I tap the board back out.
Works for me.
Calgary
Thanks this is exactly what I just did last night on my other pump, worked perfectly, although I still like to push the pump forward like 1/8" (left side is good, the right side only) , but it simply wont move forward. I did not put my whole weight on it, but I think I had enough force on the hammer.
