Belanger Saber
Zal
Illinois
Anybody have any luck getting good presoak on these? I can get good soap on drivers side snd almost none on passenger side. Belanger tech did not impress. Want to pass you off to distributor. Reminds me of PDQ before they started treating customers properly. So looking for some experienced operators to get me going the right direction
Thanks in advance!
Jsshac
Thanks in advance!
Is it both presoak passes ?
Zal
Illinois
Second pass right side is poor as well. So right side no or little soap
Zal
Illinois
I’m not too familiar with Belanger. Every other IBA I have is PDQ
Jsshac
What pump speed are you at? Have you checked the check valves on the wall manifold for the presoak? Have you checked the screen and scrubby pad in the wall manifold? Was it working before and it just started doing this?
Zal
Illinois
Just bought the place Not been good at all with presoak. Pump speed I think was 29. If I raised it then no presoak (soap)Lower didn't change anything If manifold is plugged wouldnt I loose both sides? Does it tee at manifold to both sides? Any screens in manifold?
Jsshac
Just bought the place Not been good at all with presoak. Pump speed I think was 29. If I raised it then no presoak. Lower didn't change anything If manifold is plugged wouldnt I loose both sides? Does it tee at manifold to both sides?
What is the pressure on the gauge that’s on the injection manifold when running presoak?
  • Like
Reactions: Zal
Zal
Illinois
Gauge is crap. Just got new one. What pressure should it be?
Zal
Illinois
I’ll check things tomorrow and put the new gauge in. Then I can check back in
Thanks so far for the help
Jsshac
180-200 Pump speed of 29 is definitely too high.
