FastLaneCarWash
- Joined
- Aug 18, 2019
- Messages
- 85
- Reaction score
- 10
- Points
- 8
I’m eventually going to put one at the end of the bays as well. I’m just installing them as I get money since I’m still not making any positive return on the wash yet.Those are really bright. Are you only installing them at one end, or do you plan to put a pair at the entrance of the bays too?
I might have to try one of those for lighting the rear lot at mine.
Yes they can be modified easily. I installed the receptacle on the back side of the C channel. It will be hard to get it wet but I wanted to see how well the lights held up before I cut the cord and voided any type of warranty.Can those fixtures accept conduit easily so you can hard wire them? Some ding dong is probably going to get that receptacle wet one day causing it to corrode.
If the lights last longer than the 1 year warranty I will hardwire them. I had to install the receptacle just to utilize them this way.They'll corrode over time even if they don't get directly wet. I've seen many vacuums installed with an outlet under the front cover, well away from any direct water spray or rain, and they eventually fail. May take 20 years, but it will.
It will help the direct contacts, but I've lifted up vacs that weren't working to find a steel box completely rusted away, the outlet gone, and nothing left but the wires and outlet brass corroded to the end of the cord.Ours are like this. Maybe some dielectric grease on the plug might help.
Lol not yet. But my lighting was in some pretty rough shape. I’m glad they worked out for you!!!I installed the same lights you recommend and wow. They are so bright they hurt your eyes. Have you had any customers complain about them being to View attachment 1257 o bright?
How much are they a unit?We installed these in our bays about 18 months ago. Don't have any photos of the wash but haven't had any problems.
TWR1 LED Wall Pack - Adjustable + Switchable + Photocell
The TWR LED wall pack luminaires offer a classic appearance and traditional shape to help maintain building aesthetics when replacing the entire site or only a portion of a building’s wall packs.www.acuitybrands.com
